5 members (Peggy M, Uncles51, JW51, Millenimech, Chip O), 61 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#40051 09/09/2003 8:00 PM
Where do the vaccum lines run. Do they go from
the manifold to the vaccum pump and then to the
wiper motor? Does anyone have a diagrahm? This
is on a 1950 Chevy 3600, the shop and assembly
manuals are rather unclear.
#40052 09/09/2003 8:16 PM
Someone correct me if I'm wrong, but I don't believe the 50's vehicles originally had a vacuum pump. Vacuum was manifold only - and deficiencies are when you mash down on the gas the wipers stop working! smile
If you have a double action vacuum/fuel pump, you would not use the manifold as a source of vacuum. It's either/or.
I've heard a vacuum canister is a nice addition to this setup, to give a more consistent vacuum at low RPMs. Wish I could advise you where to find one...
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#40053 09/09/2003 9:57 PM
My service manual says that if you have a double action pump you run the wipers to the pump suction side, then the output side of the pump to the manifold vacuum. The pump is mostly a booster.
Paint & Body Shop moderator
#40054 09/10/2003 6:31 AM
Boyo, they were an option on the AD trucks. If you look in the assembly manual you'll find the instructions on how to plumb them.
Fred
52 3600
69 C-10
#40055 09/10/2003 2:53 PM
The use of a lesser vacuum pump as a "forepump" for a higher vacuum system is pretty common. Here's a diagram for how I plumbed mine, just like 4ontheFloor said.
[img]http://pic1.picturetrail.com/VOL137/662484/1080315/33491508.jpg[/img]
#40056 09/14/2003 10:49 PM
Thanks for the info, the diagram looks like I
was guessing. I will get it up and running soon and give it a whirl
