1 members (TrknGMC), 121 guests, and 3 robots.
Topics128,052
Posts1,055,774
#398325 04/06/2008 1:42 AM
Apprentice
Apprentice
Ok I hsbr all the running gear, front-end and rear-end out of a 94 vette to put under my 55 Cameo pickup. Has anyone ever done this and if you have how did it go?
Man, that's gonna be a neat project! I sorta went a slightly different direction on my '37 with a Jag rear and Fatman IFS. Are you going to rework the original frame like I did or get something a bit more friendly towards the Corvette gear?
Everything is different now...
Apprentice
Apprentice
Originally Posted by rocker
Man, that's gonna be a neat project! I sorta went a slightly different direction on my '37 with a Jag rear and Fatman IFS. Are you going to rework the original frame like I did or get something a bit more friendly toward the Corvette gear?
My goal is to use something more friendly to wards the Corvette. I have a friend who is so pumped about helping me do this. He talked me into it. I had found the motor and transmit ion and told him about it, then he talked me into the vette rearend and frontend. It will be pretty cool. I plan on taking lots of pictures.
Do you have any pictures of your truck?
I saw a couple sets of C4 Corvette suspension at the PIR swap meet just yesterday. There is an outfit that makes a kit to put that suspension on an AD truck, but I don't know about one for a TF.
At the rear I think you have some straight forward brackets to build. At the front the conversions I've seen were all based on custom made crossmembers.
I'd like to see pictures as you proceed. As a C4 owner I sometimes think about what driving my '55 1st Suburban would be like if it cornered like my 'vette.
cool, I am also a C4 owner and a C3 also, old trucks and corvettes seem to go together well. I think a fully independent suspension would make the truck handle great.
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
Never went that route,but it sure sounds like a winner. Keep us posted.
Talk to Don McNeil at Flat Out Engineering. I'm in the process of installing a 94 Vette front end, rear end, transmission and LT1 motor in my 1953 5 window 1/2 ton. I bought my suspension brackets from him. It's real nice stuff. He makes brackets for a variety of models. Give him a call, he's a real nice guy and happy to answer questions. Leave him a message, and he'll get back to you.
Check out the website -www.seattlestreetrods.com/flatoutengineering.htm
