1 members (Alex52), 136 guests, and 5 robots.
Topics128,186
Posts1,057,211
Members48,465
#39817 05/18/2005 4:51 PM
Have a growl in the tranny in my 46 burb and was wondering if there is a more modern tranny (with synronizers) that will adapt or bolt right up to make it drive better. Its a 4 speed on the floor
jim
#39818 05/18/2005 9:48 PM
You can use a '49- 54 SM-420, but you may have to change the bellhousing to accept the larger pilot gear retainer. Alternately you could have your bellhousing bored to fit the SM-420.
Paint & Body Shop moderator
#39819 05/18/2005 10:42 PM
You well have to change the bell housing to use the SM-420, but that's the easy part your driveshaft and torque tube is 1 9/16 inches too long. Good Luck
It would probably be alot easier to use a 1941-47 pickup or suburban 3-speed. It will bolt in without any modifications. The 2nd and 3rd speed gears are sycronized
#39820 05/18/2005 11:37 PM
Another option would be to put in a 1946 3 speed on the floor. They have syncro in 2nd and high.
#39821 05/19/2005 12:53 AM
Jim,
If you want a 3 spd. trans. I know where you can get a new old stock one. E-mail me [email protected]
#39822 05/19/2005 4:52 PM
Thanks guys, Probably will try this one for a while but it's nice to know I have options
Jim
