About a month or so ago, I spun a thread about my O/D trans not dropping into gear. I had several good responses from the good guys on here. Thanks bunches! I did finally discover the problem.
I had forgotten that the governor switch was driven off the speedo gear BEHIND it's drive and not one from each side. The speedo worked but NOT the switch because the drive gear from the main shaft was stripped, not driving the switch. Just thought I'd feedback on what I'd found, possibly for someone else's benefit.
Tks again guys.
dg
