10 members (mk72, Guitplayer, cmayna, 5 Window 9434, Opelika Tom, TooMany2count, Otto Skorzeny, JW51, Gib70, 1 invisible), 76 guests, and 1 robot.
Topics128,053
Posts1,055,776
#39705 05/03/2002 4:17 AM
I Got a transmission from a machanic and it is out of a 1991 chev van The van had a 350 in it. Well the motor blew and the van was scraped.The tranny is supposed to be a TH 700 it has 1-2-3-OD.I am hoping to use this in my 54 P/U Would it be stronger than a 350 or a 400 tranny.The motor I am useing is a 400 hp 350.I dont know alot about trannys so any help would be great. Thank :confused:
#39706 05/03/2002 6:29 AM
That should be a TH700R4.The early ones were not that strong.Look for a later one or have someone update that one with a rebuild and use stronger parts.If you want to handle horsepower, ust the TH400.There is a place that sells performance built TH400`s and TH700R4 trannys capable of handling a LOT of torque.The overdrive is nice but they are expensive.
