Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Wheelie, ShopRag, cmayna, baldeagle, Lugnutz, Otto Skorzeny, Hawkman), 47 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#396701 04/02/2008 9:08 AM
Apprentice
Apprentice
I'm placing in a fenton dual intake as well as a fenton dual exhust on a 235 My first question is this: 1. How does the linkage hook up for both carbs. 2. How do you attach the dash throtal control as well as the dash coke cable to the set up 3. How does the gas pedal hook to the dual carb linkage and operate properly. I know its a lot question but if your going to do it you might as well do it right!
headscratch
JasonH #396757 04/02/2008 2:15 PM
Did you buy your intake from Patrick's? It should include the floating linkage and instruction page. I'm curious if the offy one comes with instructions as well. I don't hear anyone with a floating linkage complaining but I had the same setup and could never get the linkage to push the carbs equally enough to satisfy me. Good luck.
You Tube
Curt B. #396897 04/02/2008 8:11 PM
Apprentice
Apprentice
Yes it did come with a linkage I just can't see how the "the floating" is going to work properly!
JasonH #397003 04/03/2008 2:07 AM
The trick is that it needs to be bolted solidly to the throttle arms. The center arm on the linkage connects to the original upright rod from the stock linkage. you will want to use locking nuts on the bolts attaching it to the carbs. It will also take some tweeking to get the whole thing to open equally, but it can be done. i can take some pix of my Offy setup if you need to see what I'm talking about. I will warn you, mine is custom made as I am using non-GM carbs (they're off an IH), and use different arms than a Rochester/Carter. But the overall operation is the same.
Bill Burmeister
Apprentice
Apprentice
Sure, please, It could only help! Seeing it is probably a little easier then a description anyways.
JasonH #398166 04/05/2008 5:04 PM
Apprentice
Apprentice
Curt B can you give me a e-mail at [email protected] we can disscuss a solution!
Thanks Jason
JasonH #398347 04/06/2008 2:36 AM
Bill Burmeister
