| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 32 | Got a 1952 3/4 ton with a dump bed and the wood supports underneath need replacing. Can someone please recommend what type of wood is best to use? Thanks! see photo at http://www.seethepics.com/dump-bed-support.jpg | | | | | Joined: Feb 2004 Posts: 29,782 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | The usual support wood was white oak or hickory. Use something very tough and durable, certainly NOT pine, or some other type of softwood lumber. Jerry
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I can agree with oak. Are there any oak trees where you are in Il. When I pass through that state I see a lot of corn. The only thing I see in oak is the price, now if you were here in Mo. I'd cut you down an oak tree and give it to you cause I cut them down for firewood. I'd consider treated wood unless you need stronger wood. I guess it would depend on how you intend on using the truck. I burn up hickory trees to. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Jun 2007 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 32 | As a matter of fact, my dad's got oak trees coming out the wazoo and also cuts them for firewood. There is always a fallen tree on his property somewhere. Cherry and hickory too, though not as much. | | | | | Joined: Feb 2004 Posts: 29,782 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | If you can find a log with enough diameter to get a few rough-cut pieces the size you need, clear of sapwood and heartwood, take it to a local sawmill and get it cut a little larger in all measurements than you expect to need for the final dimensions. Allow at least a year for the rough-sawed wood to air-dry, then get it planed to final size. The best pieces will come from a "clear" section, with no knots or serious checks or cracks. I floored a 16 foot utility trailer with 3" thick rough-cut hickory almost 20 years ago, and it lasted until last year before it needed replacing. I don't pamper my equipment, so it saw about 18 years of hard use. Jerry
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I think it would be great to use your own oak if possible. Oak is certainly, as a hard wood, more durable than pine. There are several woods however more durable than oak or hickory or other hard woods, one is teak another is red wood. While a soft wood cedar is also long lasting. The most durable is cypress from a 70+ year old tree. I still like to local oak choice. I may use cedar from the billions of cedar trees we have been cutting for 20 years down in the hill country of Texas.
~Jim
