| | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | HI...I'm out of my comfort zone so here goes...my 1954/3100 never had a radio I would like to have one and I don't need to have an original. Is there a radio out there that will fit the face cut out for a 54. All I need is just a radio nothing fancy BUT something that will look OEM. The new OEM ones I have seen are way to expensive for me (500.00) there must be a cheap alternative in the $150.00 range? I can machine a new face plate to fit the cut out if there is a radio that is close in size to the OEM model....somebody out there must have gone this way? THANKS Steve | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The 1953/54 Chevrolet car 6v manual-tune radio fits in the holes in the dash of a 54/55 Chevrolet truck. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There is an original 54 truck radio up on auction in the "Dispatch forum" here on the Stovebolt. It has apparently been converted to 12v. I have upped the bid to $100 myself, but I will not be bidding further. I have offered to restore the electronics free of charge, at the request of the winning bidder. I may be able to return it to 6v if that is desired. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | For those of you who might be interested in a 54/55 radio, that is truly a good deal. | | | | | Joined: Nov 2001 Posts: 1,521 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,521 | Hi Steve,,If I remember correctly,your truck is now 12v? How abt. a low end am-fm,casette or c-d player mounted in the glove box and a couple speakers behind the seat,and maybe a couple smaller ones in the dash where the stock speaker would go? Ive seen it done numerous times,,always worked out well. Or.........mount something under the dash with a removable face plate. Use your Imagineering..........youll come up w/something. Happy Truckin, | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | THANKS....for the good advice! My uncle says to mount his old crank up record player(Gramaphone)under the seat....he says it would be a lot cheaper than an OEM radio....Thank God he can't find any needles for it.....T/C Steve | | |
