5 members (Otto Skorzeny, Gray_Ghost, Bill Hanlon, fonz8261, klhansen), 83 guests, and 2 robots.
Topics128,060
Posts1,055,833
#392772 03/25/2008 2:43 AM
I'm reading on this website:
http://www.britishv8.org/Articles/Borg-Warner-T5-ID-Tags.htm
that fourth gear in a T-5 transmission, all T-5 transmissions, is 1:10 to 1. That's the first time I've seen this. I have always been told and thought that fourth gear was 1:00 to 1:00 direct drive. Can anyone verify this "new" information?
Joe dang
Former Workshop Owner
According to Inliners Tech Tips and several other web sites, 1 to 1 for 4th gear is the norm.
http://www.inliners.org/
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
It's got to be a typo and he copied it all the way down the chart. I went ahead and sent them a question in the contacts and questions section.
Did you see the paragraph about which fluid to use? That discussion may flare up again.
1946 Chevy Half Ton
('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS)
1976 Margay Panther X, MC91B
Yes, D1ck, I saw that comment about the Dextron II Fluid!
I did finally get my hands on an 1985 S-10 Owner's Manual and it plainly states in there that Dextron II fluid is to be used in the T-5 transmission, so I'm Ok with that now that I have read it in person.
It will be interesting to see what this author has to say to you about his gear ratios. Let us know!
Joe smile
"MONGO"
"MONGO"
Yeah, My list I got from the HAMB years ago shows 1 to 1. I think it's a typo or wait a minute maybe it's in British units. dang
http://www.mongosgarage.com/tech/t5/T5tag.htm
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
KCMongo #393013 03/25/2008 5:29 PM
OK,if fourth gear is 1 to 1,what ratio is fifth gear?
dale937 #393054 03/25/2008 7:21 PM
"MONGO"
"MONGO"
Depends on the transmission, 1-3 and 5th vary depending on what vehicle it came out of. You can look at the spreadsheet on the link I posted above to determine what the ratio's are based on the ID Tag on the trans.
Mongo
Mongo's Garage
KCMongo #393103 03/25/2008 9:53 PM
So, KCMongo, are you saying that British RPM's are different than United States RPM's? So that means in England, the world turns fast than it does here? So LP records that are 33 1/3 here are 36 1/3 (approximately 10%) there?
I did not know dat!
OK - I got it now!!
Joe dance
Wow! D1ck, you are good! Whatever you wrote to him has him movin' fast! He has already changed all of the 5th gear ratios on the page to 1.00:1.
I just noticed that his reverse gear and first gear ratio is backwards on T-5 transmission number 1352-145 like I've got. He has first at 3.78:1 and reverse at 3.76:1. I have first gear at 3.76:1. I guess that part is still English!
Joe
KC's right again
'''''I think it's a typo or wait a minute maybe it's in British nits. '''''
you all should know about their '''old world threads'' to confuse the germans.
BSF
BSW
MA
CEI
BA
BSP
all different threads and pitchs as well as wrench sizes.
all types of Whitworth http://www.sizes.com/tools/thread_history.htm http://www.jag-lovers.org/xk-lovers/library/whitworth_system.html
I have sets of every type here, too big_eek
they were so far ahead of themselves it left our heads spinnin'
by the way joe
they have dark suckers too http://www.msu.edu/user/dynicrai/physics/dark.htm headscratch
I believe that .86 to 1 and .73 to 1 are two ratios (for 5th gear) that were standard in models. mine is .86
Jim & Caroline
Holy cow, Jim!! That is wild and wacky stuff! eeeek
Joe grin
I believe that .86 to 1 and .73 to 1 are two ratios (for 5th gear) that were standard in some models.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
I got the email back from the web site and they admitted the typo. The changed the table.
1946 Chevy Half Ton
Apprentice
Apprentice
I have a T5 from a 1985 S10 and it's definitely 1:1. Must be a typo.
5th gear varies. Most of the T5s that went behind a V6 had steeper ratios and work better behind a stovebolt. Many of the 4 cylinders had a 0.86:1, which is hardly worth shifting into.
0.72 and 0.73 are pretty common. Here's a list that might be useful....there are others if you do some searching.
T5 Transmissions
