| | | Forums66 Topics128,032 Posts1,055,528 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | I'm dropping a 454 big block into my 1958 GMC Suburban Carryall. I noticed that Jim Carter sells accelerator linkage with a firewall bracket for use when putting in a V-8 where the six cylinder used to be. Carter says "necessary if removing the original 6 cylinder." Pardon my ignorance, but why is it "necessary"? You also have to buy a different accelerator pedal (1952-1957).
Does anybody have an explanation? | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You need something, the six cylinder linkage has a bellcrank on the block that the accelerator pedal rod connects to. This would be smack dab in the middle of a cylinder in a V8. A cable linkage is going to be the easiest way around it.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | Thanks. Now that I know what the "obvious"(to the more experienced) problem is, I'll work around it. I appreciate your knowledge and help.
Mark | | |
