5 members (bobfake, MNSmith, Wayne67vert, Bill Hanlon, Hotrod Lincoln), 70 guests, and 1 robot.
Topics128,091
Posts1,056,036
Members48,433
Anybody ever tried drilled brake drums ?
Below is a link to an article that I found on line.
I know they make disc kits for our trucks, however I was thinking about trying something like this on a 39 Buick that I have which no one (that I know of ) makes a kit for.
Any thoughts, or experiences with this would be appreciated.
DRILLED BRAKE DRUMS ARTICLE
I'm also posting this in the Hi-Po Forum.
Joe - (Buckeye Bowtie)
"Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100
1971 C-10
1939 Buick Century
Never heard of such a thing, but it is interesting...
H Online: Content
It's an old weight-reducing trick from years ago, that also improves brake cooling somewhat. I've seen similar procedures done on disc brakes on roundtrack cars, and racing motorcycles.
learned another awsome trick,thanks guys ,i will definatly be doing this to my 59.. thanks guys!! smile
per their website: "...so as to eliminate balance and material integrity problems"
balance shouldn't be that big of a problem but material integrity is a big issue to me. even in disk brake applications, holes that are post machined into the rotor are known to lead to cracking after prolonged use. the consensus among people that want a performance improvement is that cross drilling is for race only, no benefit on the street, and slotting is ok. this is not a perfect analogy i know.
the issue is fatigue cracking after many many cycles as you'd find on street driven cars. race, you put new rotors on before heat cycling becomes an issue.
the holes will accelerate wear of the brake shoe too, think cheese grater.
also, that website isn't an article as much as an advertisement... www.chtopping.com referring you to C.H. Topping and Company to perform a service.
i googled it a little, seems to be pretty common practice actually, i'd just be leery with drums that are hard to find, or parts that have been turned and are near the thickness limit.
I would'nt do it. Brakes are too important to experiment with.
I like old trucks
