2 members (NJC, baldeagle),
52
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39001 10/08/2003 7:30 PM | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | First, thanks for all the help. I got my 270 in....finally, and after figuring out that my distributor was 180 deg. out of whack, it fired right up.
I plumbed my coolant lines last night and tested the engine again to make sure that there were no major leaks, there werent.
While testing this out, I ran it as close to idle as I could and when I got too lean, I would get a nice pop out of the carb. When I run it with a little more throttle that goes away. I finally shut it down after about 2 minutes of running and it knocked (at least it did not immediately stop trying to fire) and gave one last big belch out the carb.
Is this just what happens prior to breaking it in and setting the valve seats? I have checked my lashing on the valves and they are set good. What is going on here? I would love any advice you might have. The weather here has been BEAUTIFUL and I am chomping at the bit to get my truck back on the road for the first time in 3 years!!!!!!
Thanks in advance.
Tom
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
#39002 10/08/2003 8:53 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Did you check the timing ?
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#39003 10/08/2003 9:37 PM | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | I checked the timing the best I could. I am not sure how to better set the timing. I set it originally with 1 at UDC and place the distributor cap on the distributor. I have not really done much/any adjustment from that point forward. What exactly is the process that I should use? Also, would that allow unburnt fuel to pass back through the carb?
I would like to understand what is happening as well as how to fix it.
Thanks again,
Tom
#39004 10/08/2003 10:00 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Try setting the timing with a vacuum gauge. Rotate the distributor until you get the steadiest vacuum at the highest rpm..
#39005 10/08/2003 10:10 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Make sure you have the right firing order too. It will run but roughly if you have it wrong. It's 153624 going clockwise on the distributor.
#39006 10/08/2003 11:22 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I thought you said it was 536241?
54 3100 with 235 62 flatbed dump C60 with 261
#39007 10/08/2003 11:36 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | That's a little too close to my social security number for comfort.
#39008 10/09/2003 2:38 PM | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | Just so I do this right the first time.....I put the vacuum gague on the intake manifold, run the engine while checking the gague, then loosen the bolt holding the distributor to the block and twist the distributor until I get the highest level of vacuum?
I have read that I need to do this at varying RPMs. Is there an ideal RPM range (weighted average) that I should tweek to?
Again, I appreciate the advice. I just really want to understand why as much as how.
Tom
#39009 10/09/2003 5:50 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Don't over analyze this, Tom. Let the engine idle, hook up the vacuum gauge, spin the distributor....After that it will hopefully be Happy Motoring for you and your new 270..
#39010 10/09/2003 6:27 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Everybody has their own method for tuning an engine. I prefer to use a timing light, and I first set my motors to about 10 degrees at TDC. Then fine-tune carb and timing from there. Any body ever tried setting an engine using a vacuum gauge, then seen what the timing is with the light?
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#39011 10/09/2003 7:59 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 |
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#39012 10/10/2003 4:01 AM | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | thanks for all the information, it really helped. I got the vacuum gauge on and was running around 15 lbs in it current situation (backfiring through the carb). Then I advanced it 10 degrees and pulled 19 - 20 lbs at idle and no more backfire, just a nice clean idle. Now if I can figure out my throttle linkage I will be in good shape. Also, I am running around 150 degrees, basically dead center of my temp gauge and my oil pressure pegged 60 lbs at startup and backed off to about 50 after idling for 5 - 10 minutes (150 degrees). Does all this sound about right? Is there anything else that I should be paying attention to? I see no leaks, and I hear nothing really abnormal. Unfortunately I have only heard this engine run with spun bearings prior to this week so I dont have a good comparison. I appreciate all the help from you all!!!!! Thanks, Tom
#39013 10/10/2003 8:19 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It sounds like you are in good shape. That's a pretty healthy vacuum and oil pressure you have there. If the valves are a bit ticky that's normal, but if they clatter they probably need adjustment. Other than that it should be smooth and quiet.
#39014 10/10/2003 1:37 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Tom, Idling that engine is probably the worst thing you can do to it after a rebuild. Get your throttle linkage hooked up and operate that motor under a load to help seat the rings..
