3 members (Gray_Ghost, BC59, DadsFirstPickup), 95 guests, and 2 robots.
Topics128,087
Posts1,056,114
Members48,435
#38936 08/23/2004 3:11 AM
Junior Member
Junior Member
I have a 1961 chevy 4x4 I want to keep it as original as poss. the problem I am having is that the engine is allowing water in the oil what could be the cause? also is there any way to get rid of the old type of canister oil filter and put on a regular filter thanks
There are several possibilities for the water leak, none of them good, but some are easier to fix than others. A leaky head gasket can, and does result in coolant in the oil, if it gets past piston rings after puddling on top of the piston. Other, more serious problems might include cracks in the head or engine block. Some of these can be repaired. other, more sdrious ones will require replacing the damaged part. 235 engines aren't particularly scarce, but they can be pricey at times unless you get lucky.
Is the truck still running regularly, or are you planning on a long-term restoration project? I'd begin with a pressure test on the cooling system, with the spark plugs removed. After a few hours with a little pressure on the coolant, spin the starter, and see if coolant squirts out of any of the plug holes. That will isolate which cylinder(s), if any, are responsible for the leak. If water gets directly into the crankcase without entering the cylinders, the crack is probably somewhere in the water jacket at the bottom of the cylinder castings. That's a pretty serious problem, which might not be fixable without another block. Good luck, and keep us posted on your progress.
Tech tip for the full pressure oiling conversion.
http://www.stovebolt.com/techtips/full_pressure.htm
Fred
52 3600
69 C-10
