| | | Forums66 Topics128,160 Posts1,057,050 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 48 | We've tracked down universals and u-bolts for our '48 gmc fc303. It's a 2-speed axle and a 1 1/2 ton.
Next, Carrier bearing. Anybody know where we can find one for the big trucks? I've seen rubber seals, and whole bearings for smaller trucks.
Will those work? or does somebody know a part number for the larger trucks? thanks! | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | If you have the old one you could match it up, otherwise you'll have to measure the drive line where it goes and head for a parts house that carries the bigger stuff..If you're missing the carrier, then toy'll have to get complete unit, also measure center to center on the mount holes on crossmember..
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Try chevyb He had a NOS rebuild kit with bearing, rubber, and dust seals for my 1 ton, which I think is the same as yours, he will know for sure. Grigg | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy turpentyne, there is a kit listed in the parts book, but it doesn't cross into Napa numbers, however the bearing alone does. GMC 954257 = Napa part number BR88107 $36.99. It appears to fit FC 280 thru 370, hope that helps. | | |
