3 members (55shaker, Wayne67vert, Bill Hanlon), 134 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#38860 10/06/2003 4:03 AM
I would like everyones thoughts on valve seals.
I have seen many 4,6,& 8 cylinder chevy engines with stock "o" ring style valve seals that do not use any oil.
I have seen many umbrella seals that have cracked over time and use oil and p/c seals that have led to oil starved valve seizing.
I am wondering why anyone would use anything but the stock “o” ring style seals on chevs. If installed correctly they seldom fail.
Thanks, Dave
My Blog
#38861 10/06/2003 8:45 AM
Isn't it possible to use both types of seals simultaneously?
Paint & Body Shop moderator
#38862 10/06/2003 12:43 PM
Dave, I use both the stock O ring seals and unbrella seals on 2-261's and a 235 I rebuilt in my trucks.These engines have been running for years with no problems amd no oil useage.Maybe the stock o rings were fine,maybe not.
#38863 10/06/2003 9:28 PM
The O ring seals do little or nothing about running oil consumption. I just had to install the umbrellas on my fresh 235 to stop the motor from sucking oil past the guides. And the valves and guides are fairly new, only about 12K miles on them. But I have heard of the plastic seals causing oil starvation...
your results may vary.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
