8 members (SNOYL, Southerntruck, Phoneman, wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag),
155
Mod | | | Forums66 Topics128,209 Posts1,057,461 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | i have a spare 52 1/2 ton front end that im thinking about swapping with the 3/4 ton front end that is currently in my 52 so that i can adapt a 5 lug hub with disc brakes to match the 5 lug nova rear. My question is what parts can i reuse from the 3/4 ton front end (ie draglink, tie rods and steering linkage). The previous owner rebuilt the 3/4 ton front end so everything is pretty new and in smooth working order but i want to swap to the 1/2 ton front so i can add front discs. I have the 1/2 ton axle down to the beam and spindles at the moment and once i get enough cash in my truck fund and the weather gets a bit nicer id like to get out and work on it.
| | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | Every thing from the tie rod back should work..I believe the steering arms at the spindle are heavier than the 1/2 ton or at least they are drilled for larger bolts. | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | yup, when i got home from work today i got out the measuring tape and took some measurement and it should bolt right up in place of the 3/4 ton axle and all the steering linkage measures the same, bolt holes on the spindles that the linkage bolts to is exactly the same down to the size of the bolt holes and space apart from each other. Im going to hold on to the linkage i took off the 1/2 ton axle just incase, but looks like i won't have to use it. Thanks for the help. Also what does 5 on 4-3/4" lug pattern (from this kit: http://www.classicparts.com/prodinfo.asp?number=71-975W5) mean. How do they figure that out, id like to know so i can see what the rear (from a chevy nova) is. Thanks again!!! | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If the rear is from a Nova its either a 4-lug or a 5 x 4.75. Five lugs on a 4.75 inch circle which was the common Chevy car pattern for many years.
5 x 5, and now 5 x 100 (metric) are other common Chevy patterns, neither ever used on a Nova.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | then it has to be a 5 x 4.75 lug pattern, thats good, then it will match the disc brake kit which is a 5 x 4.75 lug pattern as well. Better than having 5 lugs in the rear and 8 in the front. Thanks!!! | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | what year nova? the early ears (pre 74') are really too narrow, 75'-79 nova/71'-81 camaro,T.A. work great in AD trucks | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | I wish i knew, the previous owner put it in | | | | | Joined: Mar 2008 Posts: 2 New Guy | | New Guy Joined: Mar 2008 Posts: 2 | I am looking to put disc brakes on a 3/4 ton 1951 chevy truck. I would like to keep the 8 lug pattern. Do you have any ideas?
Thanks. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Several people have done it, but its still a do it yourself project. More searching here should produce a couple threads showing how others have done it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2008 Posts: 2 New Guy | | New Guy Joined: Mar 2008 Posts: 2 | Thanks for your suggestion. Just knowing it can be done helps. In fact, we do have an idea now of how to do it. Will let you know how it progresses. Thanks again. | | |
