4 members (Woodcmiami, BillCollins, baldeagle, 1 invisible), 72 guests, and 0 robots.
Topics128,014
Posts1,055,332
Members48,419
#38631 03/08/2004 11:38 PM
I got some 4.11 gears for my 1 ton which will make it go a bit better, but, as to be expected, when I started to pull stuff apart, I found a new 'feature' in that the needle bearings in the rear u-joint were less than specification (read many broken). Anyhoo, when I started to try to dissassemble the thing, I found the drive shaft side mounts to be bent! Any suggestions on how to fix this? Right now, I am thinking about cutting the U joint in half, knocking out the parts, then heating the mount up and knocking the u-joint through it while hot to try to get it fixed.
View the squoze up u-joint holder (click me)
#38632 03/09/2004 7:13 AM
Nuthin? No ideas?
Ya chickens! wink
I might take it over to the driveshaft king here in town and see what he suggests - probably the best idea I have had today....
#38633 03/09/2004 7:36 AM
Yup, looks like it needs some perfessional help... Looks pretty worn as well as being bent, the shop can probably fix you up better than a home job.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#38634 03/09/2004 2:59 PM
My question would be are both sides of the yoke the same (dented)? I think that that it will come out with the aid of a hydraulic press. Then maybe you can reem the yoke back to original size?
Or is there anyone local that builds drive shafts? If so have them weld on a new yoke.
Thats all I have. Good luck.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#38635 03/09/2004 3:51 PM
Most towns have a drive line shop that does work on big trucks. They can build you a new shaft or cut off the ends on your old shaft, weld new ends on and balance for a very resonable rate. Those don't look like they're worth fooling with. Ck with big truck repair shops, they can steer you to a good place. Her in KC there are at least 3-4 drive line shops.
#38636 03/09/2004 5:57 PM
Thanks, I believe you gentlemen are right, and as we say the in the corn-puter trade its easier to design/fix if you have someone to argue with.
I'll get professional help....
then I'll take the driveshaft to a shop!
Let's not sink a ship for the want of a ha'peth of tar....
#38637 03/09/2004 9:33 PM
Final word on this item: I took out the drive shaft from the tranny brake drum to the rear yoke and brought the whole shootin match to a local shop.
$165 to put the whole driveline straight - new C bearing - 3 new ujoints, and the smushed up bits un-smushed.
Drive-shaft King in Dallas, Tx.
My buds have had good work from this shop, so looking forward to getting the bits did.
#38638 03/10/2004 4:16 AM
next time lots of heat push it out the bad side the cup will make the whole round, lots of heat cherry red hot
#38639 03/10/2004 4:25 PM
Sounds like a good deal. The joints and carrier bearing add up to just over $100, iirc.
Fred
52 3600
69 C-10
#38640 03/10/2004 8:47 PM
Thanks for the info Fred. BTW, Warren, the cats down there said they would grind the yokes back to round again. I thought about the heating bit myself as I have a torch, etc, but then the caps might not be stout enough, and I wonder if the heat would change their temper, then again, I wouldn't reuse em anyway, so on 2nd thought, that would probably work ok.
#38641 03/13/2004 1:49 AM
And it was only $147 drive out, plus they balanced the driveshaft and replaced the carrier. Got that in, along with 4.11 gears and I am a happy man. Much better than the 5.26 gears the thing had. I also got my windows back, so hopefully that lot goes in this weekend, and then I will ready for the bed.
