| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I've been looking for ways to clean up the engine bay and found this on ebay, but looking at my rail it looks as though I can just flip it around and essentially have the same thing without having to pay someone to do it for me. Will this work?
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I don't see why not. As long as you've got the room. They mentioned that you have to convert to a speed density if you currently use the MAF system. I don't know why!
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Sep 2007 Posts: 11 Apprentice | | Apprentice Joined: Sep 2007 Posts: 11 | some of the tpi systems with MAF have a 9 fuel injectors. the extra one is used to help start the engine when the weather is cold. its located in the middle of the left bank rail. this modification looks like it elininates the ninth injector.
also, if you have the ninth injector, you will not be able to just turn the rail around.
it's not a brick, it's cruise control.
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Yeah, that's right. That's a cold start injector, and mine, which was a 1986 MAF TPI, had one.
Later years just enriched the fuel mixture on the other 8, eliminating the need for a cold start injector.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I tried it but it doesn't work. Will send to have modification done.
