3 members (Dennys28, 87GN, 1 invisible), 113 guests, and 2 robots.
Topics128,059
Posts1,055,818
#3858 11/21/2004 2:21 PM
I remember the 1967 Malibu/El Camino equipped with the 327 cu.in. that was offered in 250 and 300 horsepower. Cannot however remember how to tell which is which. Can this be determined by the VIN, a tag somewhere or by a number located on the engine itself. Any code #'s or other factors would be helpful. Thanks in advance.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#3859 11/21/2004 3:01 PM
To identify the engine and heads, go to www.mortec.com This site tells you where to look for the casting number locationss.
Iirc, the way to tell the higher horse engine was from the front of the head. Should be two "camel humps" on the 300 hp head.
Fred
52 3600
69 C-10
#3860 11/21/2004 4:16 PM
Fred, thanks for the link aned will check it out. I do remember the double hump heads but was thinking they signified fuel injection application. Cannot remember if they were used on the 300hp carbeurated (sp) engines. Would the 250hp engines have the single or no hump heads?
Thanks again
Bruce
#3861 11/21/2004 4:28 PM
Bruce, If I remember right the other obvious difference was the 300hp had a Holley carb.
Larry
I don't own a vehicle that isn't old enough to drink.
#3862 11/21/2004 4:36 PM
H Online: Content
The original "camel hump" heads were used on 300 HP 327 engines, with a carter AFB carburetor, I think. They were also used on the fuel-injected engines, hence the "fuelie head" name. They have 64CC combustion chambers, and give about 11:1 compression with the factory .100" domed piston. The 250-horse 327 had 10.5:1 compression, with a flattop piston and a slightly larger combustion chamber. Either engine would present problems with today's gasoline. Even 93-octane gas would detonate holes in the pistons with compression ratios that high. Even with very smooth combustion chambers and an ideal piston shape, about 9.5:1 is max with pump gas. 9:1 is better. Unless you're racing, forget about the camel-hump heads!
#3863 11/21/2004 6:52 PM
I thought the Camel Hump 327 was a 350 horse engine in the Corvette. The "regular" 327 without those heads was 300 horse.
...Or could that have been because of the cam?
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
#3864 11/21/2004 7:24 PM
H Online: Content
I've seen dummies pay outrageous prices for a set of heads with those big humps on them, when a set of regular-production 305 heads will make more compression, and horsepower with just a little tweaking! People GIVE me 305 cylinder heads to get rid of them, and I install oversize valves, and do a slight pocket-porting job, and turn out more power on the dyno than the double-hump type.
Another sneaky trick is to use a set of low-compression heads from a 350, with 76CC combustion chambers, and do a .100" angle-mill job, where .100 inch of material is milled from the spark plug side of the head, tapering to nothing at the intake manifold side. The resulting chamber volume is 60 CC, more compression than a double-hump head. Add a 2.02" intake valve, and a 1.6" exhaust, plus pocket porting, and they make more power than the double-hump types. I've confirmed all this with temperature and humidity compensated dyno runs, not guesswork!
#3865 11/21/2004 10:11 PM
Back on the 327 question; I'm thinking that the 250 and 300 HP engines were dropped around 1967, re done as the 275 Hp 327 with a Q-jet with slightly less compression.All these engines used the same cam,the so called 283 Power Pac hydraulic cam, pretty mild item.The 250 hp 327 used the 283 heads with Carter WCFB.
#3866 11/23/2004 3:24 AM
A friend way-back-when had a 64 Chevelle that had a 275 horse 327, but it may not have been original. On the cam question, my dad's Motors manual from that era listed a whole bunch of different cams, but that manual is long gone. It would be interesting to get into an older manual and acrually look this stuff up, but I don't have one detailed enough that it lists things like cam profiles, or head specs. Does anyone else?
Boo Radley
We don't need no stinking V-8s!!
#3867 11/23/2004 3:56 AM
H Online: Content
I've got service manuals from Mitchell, and a few from Motor that go back into the early 60's. They won't list all the options, but there will be a pretty good cross section of the available high-performance stuff. The GM performance guru from the 50's through the early 80's was Zora Arkus-Duntov. Among his early accomplishments was the development of the "Ardun" overhead-valve cylinder heads for flathead Ford engines. Most of the high-performance Chevy engines had Duntov solid lifter camshafts, which were identified by the last 3 digits of the part number. The "078" cam was used in the 265 Corvertte engines, and the "098" cam was a solid-lift option on the 283 and 327. The 098 was also known as the "30-30" cam, referring to the .030" lash adjustment it required. That made it very noisy, a sure sign the engine was running a solid lifter cam! They ran like stink, though!
#3868 11/23/2004 6:30 PM
The original 265 V-8 was built as a low cost engine for the least expensive car GM offered.It's lightweight casting and cheapo stamped rocker arms on ball studs were cost saving measures.The fact that 50 years and 100 million small blocks later, it's still a viable racing piece is amazing.Smokey Yunick did a lot of work for Chevy on the early small blocks.Engineers found it easier to deal with an outside contractor than the eccentic ladies man that Duntov was.But Duntov did get Chevy to make in house changes eventually.Duntov wanted overhead cams,Yunick wanted a taller block and longer rods, neither guy got what he wanted.
Boo, the 64 Chevelle originaly had a 220 hp 283 as the top engine option,later in the year, the 250 and 300hp 327 became available.
#3869 11/24/2004 1:22 AM
Actually Truckedup, now that I think about it, that guys car was a '65 Chevelle SS. Boo
#3870 11/24/2004 2:06 AM
327 engine 1965, 250, 300 and 350 hp,later in the year, a limited run of 396 cars
