4 members (1955 1 Series, Phak1, WICruiser, 66flea), 93 guests, and 5 robots.
Topics128,266
Posts1,058,386
Members48,485
Does anyone have a source for Ranco heater control valves (49 1/2 ton pickup, fresh air heater)? Mine wasn't rebuildable and Chevy Duty, American Classic, etc. require a rebuildable core. I've chased a few on Ebay but so far haven't grabbed one yet. I'd like to keep the original setup rather than just stick a shut-off valve in the line. Thanks
Did you post an ad in the Swap Meet? They also show up on eBay from time to time.
1954 GMC De Luxe COE
How do you know if they are rebuildable? I have a couple but have no idea what condition they are in...
I think they can usually be rebuilt as long as the capillary tube has not been damaged.
Anonymous
Unregistered
Anonymous
Unregistered
You have a few ha ?
How much do you want for them ?
As to whether they are rebuildable, Chevy Duty told me that the area around the rubber seal was too corroded and pitted. My capilary tube was ok but the unit overall was in pretty bad shape. I suspect that most place that rebuild them need one in good enough shape to just take apart clean up and put back together with a new seal. Mine wasn't that good. I'll put an ad in Swap Meet. Thanks.
