2 members (JW51, 78buckshot),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | hello again guys. want your input on what you have experience on. my 57 now has stock master and drum drum setup. cant make up my mind wether to go with manual disc drum or power disc drum set up. how much better pedal feel is it to keep manual but disc front and drum back ? is it a noticable difference over the stock drum drum set up ? how about any of you who went with the power disc front and drum back ? any issues with being too touchy in hard braking situations ? i dont mind spending the extra money and getting a power booster, but also dont want to spend the extra money if not really needed, and if its going to amke my truck really touchy on hard braking. thanks much..... | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | p.s., my 57 is a 3100 1/2 ton with a 350 small block angine and th 350 auto trans. modern early 80's truck rear. just a cruiser, not a fast race truck.
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | I've got disc front/drum rear without power and it works fine. I'm using a Mustang II master cylinder that mounts under the floor where the original mounted using a kit from Fatmans.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've got manual disk/drum and it works just fine. I do notice a difference going from a power brake vehicle to this one, but after a few stops I adjust and its fine.
More important than the power booster is getting the parts to work together. Make sure you have compatible parts at both ends, and the right master to go with them.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'll throw a different opinion on this. If you go disk, go for the power option, too. I've had bad experiences with manual disk brakes on trucks, not enough stopping power as disk brakes are not self energizing like the Bendix drum brakes that they come with. I know a guy that had a '78 Dodge Warlock that had manual brakes, that thing wouldn't stop for nothing!
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks do much guys for your input... will decide hopefully in about a month or so.... decisions decisions. LOL. ...leonard. | | |
