Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (TexasFarmTruck, crenwelge, Mike1933, tclederman), 227 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#38422 12/22/2004 2:36 AM
Hello all. Anybody have some good advice on how or what to fashion a water heating plate out of? It's for Fenton's and Tom Langdon has recommended the water vs. exhaust setup as have many other folks on this site. I am already setup with exhaust heat since that is what the headers came configured with. But I have not seen a water setup and I am having problems imagining where to start or what to use to fabricate the plate. Please chime in with any suggestions. Thanks. grin
Whad you do?!?
Shane
1953 Chevrolet 3600
#38423 12/22/2004 12:26 PM
On my 250, I made a plate of 1/2" aluminum, drilled & tapped mounting holes and 1/4 NPT for the plumbing. I used 3/8 steel tubing tee'd off the heater hose fittings on the water outlet and water pump. Works fine.
One note - my Offy intake had core plugs in the bottom that leaked like a sieve. I JB'd them and have had no problem. Check before you fill it all up with anti-freeze.
