| | | Forums66 Topics128,261 Posts1,058,345 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 85 | On the heaters that have two motors,a defrost and floor fan.What type of switch is used?Right now it has one two speed switch that runs both fans in high and low.Shouldn't they be seprate? | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | You can run one or two, depends on your preference. You can get rheostat switches from all of the vendors for the heaters. I'm assuming your two speed is a paddle switch. I'm not aware of anyone repoping those so you'll probably want to hang on to it. I use a rheostat for my heater and a two speed paddle for my defrost.
| | | | | Joined: Jan 2008 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 85 | Thanks,I think I might do what you said, that way I can control it better. | | |
