2 members (DaveV, Napco Man), 99 guests, and 1 robot.
Topics128,260
Posts1,058,343
Members48,485
#382914 03/03/2008 6:17 PM
On the heaters that have two motors,a defrost and floor fan.What type of switch is used?Right now it has one two speed switch that runs both fans in high and low.Shouldn't they be seprate?
48 one ton #382924 03/03/2008 6:35 PM
Ex Hall Monitor
Ex Hall Monitor
You can run one or two, depends on your preference. You can get rheostat switches from all of the vendors for the heaters. I'm assuming your two speed is a paddle switch. I'm not aware of anyone repoping those so you'll probably want to hang on to it. I use a rheostat for my heater and a two speed paddle for my defrost.
Tiny #382940 03/03/2008 7:19 PM
Thanks,I think I might do what you said, that way I can control it better.
