4 members (78buckshot, klhansen, 2 invisible), 147 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#382073 03/01/2008 4:37 PM
I'm installing a CPP disc/drum framerail kit on my '57 3100. The kit gives you the option of running a single front line and tee-ing to each front wheel or a separate line to each front wheel. Single lines better? Or does it matter?
3B Offline
Hy 57 Chev, it makes no difference to the systems function, which ever way is easier for you to do is fine, hope that helps.
3B #382199 03/01/2008 11:48 PM
The separate line system routes the right wheel line across your tranny support. This is what I did because it meant less tubing and less Ts etc. However be prepared to undo the line if when you ever need to pull the tranny.
http://good-times.webshots.com/photo/2496126880099708909eYOmle
http://good-times.webshots.com/photo/2296483650099708909REbVvy
http://good-times.webshots.com/photo/2347808180099708909POMndH
http://good-times.webshots.com/photo/2143355100099708909ILhKhC
http://good-times.webshots.com/photo/2945019710099708909FleCsL
~Jim
Thanks.
