6 members (Guitplayer, Otto Skorzeny, Phak1, tclederman, R&S 51 GMC, Wayne67vert), 141 guests, and 1 robot.
Topics128,125
Posts1,056,338
Members48,440
Hey does anyone no why the holes for the rivets on these side plates are approx .030 bigger than the normal rivet size? I measure them at .405 and .345 . Has any one welded new sections to these where they rusted and got thin on top?
To install a hot rivet you need the hole oversize for the rivet, otherwise you can't get it together in a hurry, in addition to the rivet expanding with the heat.
The hot rivet should swell up and fill the hole when you set it/form the head on the other end.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
What about welding a piece of steel... say 3" wide along the top. Do you guys think this is a definite "no do" or would it be okay? I just priced out the whole side piece and I think I can save some money if I just replaced the thinned out section.
It's a possibility, You will be removing the entire side plates first right? Making a full penetration weld the entire length of the plate, about 3" from one edge, not in the center of the entire plate, could be asking for problems with it warping and bending. That said, I expect it can be done with some careful welding and possibly hammer work once done.
If you try to trim the bad part off in place, and weld new on in place that is a lot of work too, and you won't get all the rust out from between the old parts.
I know steel is expensive, but considering the aggravation, welding time, and quality of the final product, I would go with the entirely new side plates.
All depends on what you want?
Grigg
---All pictures---
Welding frames hasn't been advisable for a long time, because they are heat-treated; welding will destroy the heat treatment for some distance from the weld. I don't know if yours is in that category, but I would avoid welding. On newer trucks, drilling is even prohibited.
Harvester
