| | | Forums66 Topics128,272 Posts1,058,420 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 48 Apprentice | | Apprentice Joined: Jan 2003 Posts: 48 | For those of you who need a dome or interior light and don't want to fool with wiring to the 6 volt system in your truck here is a slick solution: Coleman makes a battery-powered light with a magnet on the back that you can attach almost anywhere in your truck - under the dash, above the rear window, under the hood. Here is a link to it: http://www.coleman.com/coleman/colemancom/detail.asp?product_id=2000000032&categoryid=6000Coleman also makes a battery-powered fan for use in tents that has the same magnetic back. You can stick it almost anywhere. And the color matches my interior! I found both at a local sporting goods store. Here is the link: http://www.coleman.com/coleman/ColemanCom/detail.asp?product_id=830-350I love an easy fix. Wilber
Don't read the directions, that'd be too easy.
