4 members (Hotrod Lincoln, Simon1954, Otto Skorzeny, klhansen), 37 guests, and 9 robots.
Topics128,012
Posts1,055,315
Members48,419
#38141 12/02/2005 4:30 AM
I have a 66 250 block sitting around and was considering rebuilding it. I disassembled the head and found that the valve seats and ports were rusted from sitting in the weather for the last 20 years. Would it be cheaper to clean it up and remill the valve seats myself since I have access to a milling machine or to just go and buy a new one? Also, is it possible to put small-block chevy roller rockers and roller lifters in this thing or are there companies that make performance parts specifically for inline sixes? Thanks, Drew
66 Chevy C-10 stepside- love every bit of it
#38142 12/02/2005 4:46 AM
small block roller rocker and rolloer lifter will not work. the six rocker are on there on with 1.75 ratio regluar small block lifter will work. there is a few companys that make roller cam for six but they are hard to find not much call for them. do a web search and look for cam company online catlogs to see if you can find the roller cams. big block roller rocker will not work also. tried this one my self and they just dont fit. harland sharp does make roller rockers arms for inline sixes. and they are made in the USA.
super250six
#38143 12/02/2005 5:59 AM
Crane has aluminum roller/rockers for the 250/292 and Crower has them in steel and I think those will fit under the stock cover. You'll probably want to consider hardened exhaust seats, because of the unleaded gas. You may want to do a little reading about this engine and this book by Leo Santucci has some good info.
[img]http://www.inliners.org/merchandise/images/chev_ex_small.jpg[/img]
'67 GMC 3/4 292 4spd
#38144 12/02/2005 8:10 AM
I have a set of Harland Sharp roller rockers for my 250. They're the BB chevy rockers, so the ratio is more like 1.7 rather than 1.75...but my cam is a bit lumpy, so the smaller ratio will smooth it out a bit.
1954 GMC De Luxe COE
#38145 12/02/2005 11:12 PM
Riding in the Passing Lane
You could take the head to a automotive machine shop. They will hot tank it & grind the valves & seats. Like Richard says you will want to get hardned seats. You could get a 71 up head or a 292. They have hardened seats.
1972 Chevy c10 Cheyenne Super
#38146 12/07/2005 9:52 PM
Junior Member
Junior Member
I have the stainless Crowers and they do not fit under a stock cover. They work under a 235 cover(with adapter) or a Clifford with some clearancing and two gaskets. Crower also makes roller lifters for Chev inlines.
Two places that are inline specific are Stovebolt Engine Company and Clifford Performance.
