| | | Forums66 Topics128,035 Posts1,055,570 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38030 11/10/2004 11:51 AM | Joined: Jul 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 60 | Has Anyone in here had much experiance with rebuilding 216's. I am pretty mechanically inclined. I have never ebuilt an engine before though. My only setback would be the babbit bearings. Thanks, Jess
1951 3100
#38031 11/10/2004 2:14 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Jess, the hardest part of rebuilding my 216 was finding a machine shop that had some knowledge of them. After asking around at shows and quizzing several VCCA members,I located a shop about 40 miles from me that had experience with them. They converted the rods to insert bearings so that eliminated the shims there. After that, the only thing that took a little time was setting the shims on the main bearings. Other than that, it's basically the same as building any other engine. Pistons,bearings,etc. are readily available from federal Mogul,etc. | | |
#38032 11/10/2004 5:45 PM | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Jess,
I am rebuilding my 216 too. You can go inserts or you can send the rods to a babbitter. I elected to keep my rods and have them rebabbitted. I gave him the crank rod journal dimension because they were machined .010. He will cut the babbitt to match. If I understood him correctly, I may get away without having to install the shims. There are many threads on babbitt vs inserts. It's what ever you want. Let us know what you decide and progress.
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
#38033 11/11/2004 9:38 AM | Joined: Jul 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 60 | new question... To re-babbitt do you just get the crank worked on? Or does the whole block have to be there as well? I'm thinking this will be easier to just buy a rebuilt 235. Too muching thinking on my part going on here. Boy I love my truck...
1951 3100
#38034 11/11/2004 9:39 AM | Joined: Jul 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 60 | and by crank i meant rods. Jess
1951 3100
#38035 11/11/2004 12:25 PM | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Jess-
All you need is the rod journals on the crankshaft to be machined true-so they are not egg shaped. The block does not have to go to the babbitter. Get the dimensions from the machinist and send the dimensions and the rods to the babbitter. I have been told by my babbitter that if I didn't care about keeping my rods, that as soon as he has my cores and dimensions, he would cut and send some that he has on the shelf. In this case, you would have fresh rods in about a week. Hope this helps.
Mark
#38036 11/11/2004 2:36 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The way the original rods were done, they came out of the factory with .004" of shims in the rods. With reconditioned rods, I would think that they would be set up the same way. It sounds like there is an independant shop that will make them precise enough to be used as is.
I had my rods machined to take inserts. The inserts are made of more advanced multi layered material. They are of similar makeup to other modern inerts. They should have a longer service life than the old style rods.
On the 235 quetion, a more modern full pressure 235 would take more abuse and would do better at the higher RPMs. | | |
