0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38026 12/19/2002 4:03 AM | Joined: Nov 2000 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2000 Posts: 21 | Been looking for 6 lug rear axel for my 48 half ton. Found 85 Blazer 4X4 rear axel for reasonable price (very reasonable). Rear axle in my 48 is just over 62 inches, does any one know the width of the 85 Blazer. The Blazer is about 2 hours from my home, trying to avoid the trip if it is to wide.
1948 Chevy 5 window "6" powered
#38027 12/19/2002 7:20 AM | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Couldn't you just measure any '85 Blazer parked near by? Sorry I don't have the measurement | | |
#38028 12/19/2002 8:32 AM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Larry, you might want to check the "Tech Tips" section here at Stovebolt-I think there's a listing of different rear axle widths which includes your Blazer. Also, I believe Tony and Joy Pascarella used a Blazer axle under Joy's AD-give him a PM and ask, he's always helpful. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
#38029 12/19/2002 11:25 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | You rang? a Blazer or Chevy 1/2 4x4 ton axle works out just fine .Mine is a 12 bolt with 3.40 gears, a 235 will pull 3.08 gears easily. | | |
