4 members (Charles in CA, 52Carl, bluechev, TooMany2count), 74 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#379857 02/25/2008 12:57 PM
what is the bolt circle pattern for a factory 6 lug wheel on a 57 chevy 3100 ?
thanks much
1957 Chevy 3100 1/2-Ton
Photobucket pictures
6 Hole with a 5 1/2" bolt circle.
TruckNut
Be kind, courteous, cheerful and helpful - And someone will take advantage of you.
"Quiting smoking is easy, I've done it hundreds of times." Mark Twain
1/2 ton wheels interchange up to '70 on 2wd, up to '87 on 4x4. The 4x4 wheels will work on the '70 and earlier 2wds.
Bill Burmeister
does american racing wheels make a rear rim in the torque thrust wheel that is 6 lug 5 1/2 bolt pattern, or other comanies ? or am i stuck with factory style wheels and hubcaps ?
thanks.
Former Workshop Owner
Lots of wheels are available. Check out your local custom wheel and tire stores.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
jeep 6 lug also work
Jim & Caroline
They do make a Torque Thrust style 6 lug, but it is only made in the late model backspace for '99-current Silverado/Seirra. Won't interchange. Chack out Halibrand if you're looking for old school style wheels. Also, American racing does make the Salt Flat Special in a 6 lug.
Bill Burmeister
thanks longbox for the helpful tips.....
