0 members (),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37934 06/09/2002 10:07 PM | Joined: Jan 2002 Posts: 24 Member | | Member Joined: Jan 2002 Posts: 24 | Bought me a "new" truck last week. 1967 C-10 LWB. Pretty nice truck, 'sept for the huge puddle of trans fluid underneath. Fluid pours out the front as fast as it goes in.
Pulled the inspection cover and found the bolts that hold the pump have backed out on all but two. I can't reach the top ones for the torque converter. Any ideas...other than pull the thing out? I'm pretty sure it need to come out, but I want to make sure before I go to all that work.
Beat to fit, paint to match
#37935 06/09/2002 11:47 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Hmmmm,,,,Yes, it will have to be pulled to get to the pump bolts. . . . BTW,,, this thing sounds like a TH400,they are notorious for that happening.
