8 members (Gdads51, Sjm, TooMany2count, 52Carl, greenie-reddy, 78buckshot, Wayne67vert, Wally / Montana),
102
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,262 Posts1,058,331 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 8 New Guy | | New Guy Joined: Feb 2008 Posts: 8 | Does anyone know if a 39 windshield crank handle can be made to fit a 36 regulator? The 36 has 16 splines. Anyone know how many the 39 has?
Thanks. | | | | | Joined: Feb 2001 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 96 | Yes, the handle will fit I have used a 46 handle on a 37 regulator. The difference in the regulator is in the length of the shaft that handles fits on. The 40 to 46 has a longer shaft to come up through the rounded dash. There is an article in the tec tips if you need to take one apart. | | | | | Joined: Feb 2008 Posts: 8 New Guy | | New Guy Joined: Feb 2008 Posts: 8 | Do you know if the 37 is the same as a 36?
Thanks | | | | | Joined: Feb 2001 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 96 | The 37 to 46 are 16 splines. The windshield is a different size. Finding parts that interchange for that 1/2 year model isn't easy. | | |
