| | | Forums66 Topics128,259 Posts1,058,292 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | Took my 56 to the muffler shop today and had the exhaust extended over the rear axle to the rear of the truck. It was turned down just forward of the rear axle and quite noisy. The new setup is much quieter, but tight. I could use another two inches between the rear axle and the body/exhaust. I have the 79 Camaro frontend clip and rearend. Could I just use some of those lift blocks and u-Bolts at my FLAPS? | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 |
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
