3 members (Paul_WNC, 3B, 1 invisible),
80
Mod | | | Forums66 Topics128,082 Posts1,056,324 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37697 12/15/2004 1:00 AM | Joined: Nov 2004 Posts: 19 Junior Member | | Junior Member Joined: Nov 2004 Posts: 19 | I've got a '66 C-10 with 6-lug wheels, and all the coolest wheels are for 5-lug. How can I convert to 5-lug without a whole new rearend?
---Mark, Tucson, AZ | | |
#37698 12/15/2004 1:24 AM | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | You can change out the axles from a 71 or 72 c10 all you need to do is remove the cover at the ring gear remove 1 bolt slide out keeper pin and slide C-clips off and reinstall, easy change. | | |
#37699 12/15/2004 2:16 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | don't forget to get the axles shortened 3/4s of an inch or make spacers for behind the brake backing plates. | | |
#37700 12/15/2004 4:44 AM | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | i see that alot of people make this change from 6 lug to 5. why is it done? any other strange advatage the 5 lug has over the six or is it usually just to accomodate a special set of rims? | | |
#37701 12/15/2004 12:52 PM | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | I'm considering this change so that I can use the kind of 5 lug rims that I like. There's just more variety in the 5x4.75 bolt pattern than the 6x5 pattern.
Someone told me today that he knows of a company that will fill and re-drill the axles and hubs. I plan to check that out. | | |
#37702 12/15/2004 11:40 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Correct me if i,m wrong but I believe the 71 up trucks are 5 on 5.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#37703 12/16/2004 12:17 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Originally posted by Murdoc: i see that alot of people make this change from 6 lug to 5. why is it done? any other strange advatage the 5 lug has over the six or is it usually just to accomodate a special set of rims? I believe most people go 5 lug because 5 lug front disk brake conversions are cheap compared to 6 lug. You can find 5 lug front disk units plentiful and cheap in junkyards. And they'll easily go on the earlier (pre-'71 back to '63) trucks. I'm not aware of any factory GM 6 lug (with a 6 on 5.5 bolt pattern) front disk brake front ends that will easily fit the hub of the pre-'71 half ton trucks. And although they'll allow you to keep your stock 6 lug rear end, the aftermarket 6 lug front disk kits are far from inexpensive. It's usually quite a bit cheaper to buy a 71-72 (or later) junker and steal it's rear axle and front disk assembly than to buy the brand new 6 lug front disk conversion kits. -ftyler | | |
#37704 12/16/2004 2:55 AM | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I am reading my new catalog from Early Classic Enterprises ( www.earlyclassics.com) I received in the mail today. After looking at many of the aftermarket 6 to 5 and 6 to 6 disc brake conversions, it looks like ECE is very comprehensive in equipment choices. Additionally, it apprear the offer stock and drop spindles for '60-'72 Chevy/GMC trucks. FYI-American Racing offers many wheel styles in the 6-lug pattern that comes stock on these trucks. Being somewhat of a purist, I prefer to stay with the stock 6-lug setup, especially since there are so many aftermarket options available for '60-'66 Chevy/GMC trucks. | | |
