2 members (John Dlugos, 1 invisible),
150
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37654 02/11/2003 12:18 AM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Hey guys, Is there a way to mount the 235 oil filter can on the firewall? I'm running the clifford 4bbl and fentons, so no stock location for me. Is there a kit or something out there to mount the filter where the voltage regulator used to be on the firewall?
This oil pump mishap has me re-thinking the bypass oil filter.
thanks chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#37655 02/11/2003 12:54 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can mount it anywhere you want as long as it sits straight up and down and it's set out from the firewall to remove the lid. All that will take is a spacer, which you can make with a hacksaw, file and drill. Once you mount it, then you can measure and get some new hoses, either at a parts store or at a hose shop.
But, how about converting to a full flow filter? I can't recall how deep you are into the engine.
Fred 52 3600 69 C-10
#37656 02/11/2003 2:02 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I don't think the 235 filter flows enough for a full flow conversion, though. The 261 oil filter takes bigger filters and has much bigger lines.
#37657 02/11/2003 2:07 AM | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | I welded a bracket and mounted mine off the frame. It has to be pretty solid though. The filters are pretty heavy when they are full of oil. I had thought about converting to new style but also heard that they are too restrictive for stock 235 oiling. | | |
#37658 02/11/2003 2:56 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As stated above, the 235 full-pressure engine ('54-'62) has to be converted to a full-flow oil system before you can convert to a spin-on filter. Check out the Tech Tips, Full Flow Conversion article on the Inliners site: http://www.inliners.org/ The 1958-1962 261 (Chevy truck) engine was a full-pressure, full-flow engine. It is ready for conversion from the (tall) canister oil filter to a spin-on oil filter. In would be interesting to hear from someone who has done this conversion. A spin-on filter conversion kit can be purchased for about $25 (complete with fittings, lines, and filter head but no filter). This is easy to mount on the firewall (this is what I have done with my 1960 261) or low on the block (within the last month there was a posting in this forum with pictures - on a 261, as I recall). Tim | | |
#37659 02/12/2003 12:12 PM | Joined: Feb 2003 Posts: 25 Member | | Member Joined: Feb 2003 Posts: 25 | SO WHAT I AM HEARING IS THAT ON MY 235 WHERE MY TO AND FROM LINES ON MY CANISTER FILTER ARE, I CANT JUST RUN THOSE LINES TO A REMOTE FILTER DUE TO NO ENOUGH PREASURE? | | |
#37660 02/12/2003 1:37 PM | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | I've seen 235s converted to a full-flow filter with no apparent ill effect. Requires bushing down the filter head fittings to the small lines used with the bypass filter. Owners claim no loss of oil pressure, but any advantage would appear to be convenience, because the filtered oil still goes right back into the pan to mix with the dirty stuff. A true full flow conversion returns filtered oil to the the main oil galley, upstream of the bearings and rockers. | | |
#37661 02/12/2003 8:58 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by codeman: SO WHAT I AM HEARING IS THAT ON MY 235 WHERE MY TO AND FROM LINES ON MY CANISTER FILTER ARE, I CANT JUST RUN THOSE LINES TO A REMOTE FILTER DUE TO NO ENOUGH PREASURE? That's not what we're saying. Your current filter is probably set up as a bypass filter, only about 10% of the oil that is pumped goes through the filter, then is dumped back into the oil pan. There is another option when you have the engine apart for rebuild, which is to convert the engine to a full flow filter, where all of the oil pumped passes through the filter before going to the oil galleys to lube the engine. The full flow filter is better than the bypass, but the bypass is better than no filter. There is an article on the conversion int the tech tips section.
#37662 02/12/2003 9:00 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Codeman , you can indeed mount the filter to the firewall , that is how the dealer mounted it in my '49 . you'll need slightly longer lines .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
