8 members (55shaker, classicfins, 37 GC, Otto Skorzeny, Shaffer's1950, 1946chevytruck, CandoBrent, 1 invisible), 80 guests, and 3 robots.
Topics128,128
Posts1,056,661
Members48,450
Help, please:
Am trying to return the '55.1 4400 Dump to usable condition, which means a complete brake system overhaul.
Of course, my front wheel cylinders are pitted, too much so for me to be comfortable in rebuilding them.
Here's my question: 1954-55 being a split year, seems to have to different size wheel cyls on the front axle: 1" on early production; 7/8" on the later production.
My truck has the 7/8 cyls, which seem to be no longer available, aftermarket; however, Raybestos still carries the 1" bore cylinders for $36.00 each.
How would the additional 1/8" in bore affect the braking of the vehicle? Enough to worry about it?
The front brakes are 14" x 2 1/2" and the rears are 15" x 4", and it has a Hydro-Vac.
Any ideas? :confused:
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
ook i just got off de phone with me brake guru that has furnished parts and relined all my ol time big truck brake stuff and he sez he don't know why they went from 1' to 7/8' but if you install the 1' cyls you will be good to go if anything you will have better brakes
i thinkzz traveling along at terminal velocity will soon wear a body out.
i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
That change will increase your braking power on the front 25%, which will mean that when empty your rears won't be as likely to lock up, but when loaded the rears will do less of the work. You can also have the cylinders sleeved, your parts store should be able to price that for you. If it were me I'd buy the 1" cylinders.
Fred
52 3600
69 C-10
Thanks Guys!
Will let everyone know how this saga turns out;
Still have to pull the rear wheels and see what "hidden delights" await there!
Frank McMullen
