| | | Forums66 Topics128,089 Posts1,056,116 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Has anybody removed the sliding side windows on a 60-66 Burb and installed 1 piece glass? I will retain the original pillar .My reasoning is, plenty of bolters are looking for the handles since they are rare as "hens teeth" and you can't keep the water from rotting the bottom of the panel out.Any help would be appreciated.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Many or most Suburbans came with one piece (I think in the rear set), as you know, so you just buy the one piece rubber and go to glass shop for glass. Take out the frame on the slider and put one piece in. Is that your question? Don't know what you mean by retain the pillar.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | If you decide to keep sliders, I have latches for sale.
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: Apr 2002 Posts: 5 New Guy | | New Guy Joined: Apr 2002 Posts: 5 | i`am intrested in the latchs. send me a pm | | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | bartamos, What I ment by the pillar is the roof support between the 2 sliding windows.Your suggestion sounds right on line with what I have in mind.Thanks
| | | | | Joined: Sep 2007 Posts: 20 Apprentice | | Apprentice Joined: Sep 2007 Posts: 20 | I am interested in some further discussion regarding the windows. My burb has sliders for all four windows. I have latches that won't catch because the window glass is a little long or the tracks are not square/smooth enough for the glass to seal at the rear of the window.
Does anyone know of a sources for detailed drawings with dimensions for the windows, tracks, etc. so that I can check what is wrong and get some new items, or make them up out of existing items.
OR does anyone know a source for the proper rubbers and sweepers for the sliding windows, or a cross section of the molding, including the part that should go over the center of the window bar where the slider latches.
I realize it may be a long shot, but gotta hope somebody has done some of this. Thanks. Bert.
Bert 1964 Chev Suburban
