9 members (3B, Bill Hanlon, JW51, 57 Drifter, Gdads51, Otto Skorzeny, Gray_Ghost, DennisM, rick46ia),
64
Mod | | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | Opinions please....is this a copmplete correct carb that I could put on a 55 235 chevy in a 52 truck? Would this type of carb be a good choice? Thankshttp://cgi.ebay.com/ebaymotors/early-carter- http://cgi.ebay.com/ebaymotors/early-carter-YF-list-2100s-good-shape-1bbl-rare-survivo_W0QQitemZ180209230471QQcmdZViewItem?hash=item180209230471&_trksid=p3286.m20.l1116
Hope I did that right.....
1965 chevy c-80 409 5-2 20000 original miles. 1965 chevy c-60 348 5-2 single axle tractor. 1952 chevy p/u 235 4 speed restored. 1965 chevy c-60 couch. One grouchy wife. FOR SALE....CHEAP!!!! The future is not what it used to be..... Have a new pair of metric vise-grips and large metric hammer, can fix anything...
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | CarbKings list says it is for 1950 and newer engines. Manual choke and a size 3, meaning it fits the larger sized intake manifold. It looks good to me for what you have described.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | Thanks. was wondering if those were all the correct casting numbers for that carb or if it is a hodge podge of several carbs scabbed together to make one. would be going on a BONE stock 1955 235 currently installed in a 1952 p/u 4 speed.
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I don't know anything about the casting numbers, but if the price is right,it may be worth a gamble.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | GoodWrench,
55 chevy but what motor you have , if it has 216 motor and to put 235 carb you need to tinker something with manifold otherwise it wont fit
my 2 cents
Ganesh | | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | Thanks guys... it is a 1952 truck with a supposed 1955 235 engine, I have not ran the numbers yet though (dont know where they are)
