2 members (dt235sd, Bucker), 146 guests, and 0 robots.
Topics128,196
Posts1,057,390
Members48,471
Finally! After three months of sitting in my garage, and after
getting the brake work done, I take my recently acquired truck for a
drive, only to discover a very pronounced shake in the drive train.
I'm pretty sure it's not engine related as the engine runs well at
idle, and at higher rpms while in neutral. The shaking starts
apparently in fourth gear and I'm afraid of going any faster. From
experimenting it does not seem to 'shake' while there is torque on
the system (accelerating/climbing hills/etc) only when I let up on
the accelerator does it become noticable, and more pronounced the
faster I am going. Top speed tried: 45MPH. I was unable to determine
the location of the shake (and it is very audible as well) When I pop
it in neutral the shake continues. Once below 30 MPH, the shake seems
to go away.
Any ideas?
Mike
'51 3100
Wow , the potential list of options here seems nearly endless .
I'll give you a couple and let the others climb all over them .
tyre delaminating
tyre balance weight come off
Wheel incorrectly fitted after brake job
flat spot on the tyres after sitting 3 mths
Mike, how about the differential in your truck, is it in good condition? The conditions you are describing ring a bell to me, especially the vibrations not occuring under load, just cruise and coast. Sometimes, uneven wear patterns on the ring and pinion gears in the differential can cause the condition you described. I seem to remember reading an article in "Classic Trucks" magazine which gave a list of symptoms and causes within the differential. This list was a sidebar to an article on differential and rear suspension overhaul on a early 70's Suburban. I can't remember which issue it was in, I'll have to check my "library" and get back to you with another post a little later.
Wannabe smile
no truck right now...
one day WILL HAVE an Advance Design Chevy...
"Don't expect anything and you'll never be disappointed"
If it is a closed driveline (torque tube) if would first check the u-joint and the oakie bushing.
have you done any driveline work on it? (like taking the driveline out) Cause if you dont put it in the same position as it was before, it will throw the balance of the driveline off, causing it to vibrate.
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
The tires are brand new, less than 10 miles on them. All the brakes are brand new. New wheel bearings in the front.
Engine runs fine, load or no load. I suspect Universal Joint, but unsure of how to determine the difference between the two types of drive shafts. (Torque tube versus Open) (WEll, I am new to this.)
Mike
Wow, two month stovebolter and I already know some asnwers.
The torque tube has a shaft within a tube, there is no moving parts visible.
An open driveshaft has the turning shaft out in the open and you can see it turn when the truck moves.
The former is actually akin to a propeller shaft and so named in the shop manual.
54 3100 with 235
62 flatbed dump C60 with 261
If you have a 2 piece drive shaft then it needs to be timed. I am not sure if your model has a 2 piece drive shaft.
kdot em3
Mr. Tankslap lives in my 39 but at 80-85 or so It'll tear your thumbs off the wheel!!!!
That is why good drivers always have their thumbs up when their hands are on the wheel!!!!!
Mikes51Chevy: You did not say if you had any trans or engine work done to your truck. You stated that you can feel and hear the noise, and at about 30mph, out of gear It's still there.
1. Check transmission for tightness to bellhousing
2. Check trans oil level, pressure plate tight?
3. Check driveline, timed and u-bolts tight.
4. Check rear end oil level. Check tires/flat spots, or blisters, missing tread.
5. Check pinion for looseness or leaking oil from rear. Possible loose rear gears or bearing noises and/or vibrations. Maybe a loose rear wheel. More likely worn axle bearing, or pinion. You said the noise is apparent when no torque is to rear, that points to rear gears (ring loose or pinion worn),
worn bearings and things moving (thrust) around.
6. An easy check is to support truck frame on jack stands, or blocks to frame. Remove rear wheel/tires and place a floor jack under rear end
differential. Also block front wheels both ways.
Start truck and check for noises, easy to locate with wheels off. Rev truck up to about 45, and let off. If you can't tell, rev to 45 then shut off. By careful listening and checking you will be able to pinpoint the trouble. Good Luck!
Think Chevy! wink eek :rolleyes: : ( :confused: :confused: :confused:
Houston? , We have a problem!
Quote
The best drivers steer with their knees. You need your hands for eating hamburgers, talking on the phone, and shaving/applying makeup.
Paint & Body Shop moderator
Junior Member
Junior Member
I had a vibration in my 53 that started at about 45 MPH and got worse as I increased speed. The problem was the carrier bearing. Mine is a one ton long bed and has two shafts with a carrier bearing in the middle of them. I'm not sure from your post if yours is a single or double shaft but it might be worth looking into. Good luck.
