| | | Forums66 Topics128,206 Posts1,057,435 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37138 08/09/2003 5:00 AM | Joined: Jul 2000 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 30 | Tonight was the first chance I've had all summer to work on the truck. The clutch needed to be adjusted so under I go. My arms aren't long enough to reach from the top. While I was down there I noticed a drip from the oil drain plug. Also noticed a bit of that same rust proofing spattered back on the clutch housing and tranny. I wiped off the plug and continue working my way back. It gets a bit thicker here so I use a putty knife. I'm scraping under the clutch housing and suddently I have liquid spurting out from a hole. Doesn't smell like antifreese, looks like dirty water. About a cup or so I'm guessing. What's this hole for? I checked through my reference books and didn't find anything. I found a small cork and stuffed it in the hole for the time being. It's roughly 1/4 inch. Is it a weep hole or should there be a plug in there? I took a quick picture but am not set up to post it anywere yet. TIA
Deaner 1950 Chevy 3600 Stake Bed
I don't know where I'm going, but there's no sense being late!
#37139 08/09/2003 5:05 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | It sounds like a drain hole on the clutch cover. It was plugged and held the water in there. Water cooled clutches don`t work too well for your application Are there about 4 screws holding the tin cover on the bell-housing?
#37140 08/09/2003 2:35 PM | Joined: Jul 2000 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 30 | Mech....not that I noticed. More of the "rust proofing" material.  I'll check later today.
#37141 08/11/2003 10:51 PM | Joined: Oct 2002 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 69 | hmm,interesting..! i better check for that under my truck then, anyone else have this happen on their rig(s) ?
thanks
Randy the easter wabbit ! -here to help fellow enthusiasts as best as possible  parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others, | | |
#37142 08/11/2003 11:15 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I found the clutch housing cover on my truck to be rusted out. I think it is a self-correcting problem, so to speak. The water gets in there from water that runs down the cowl due to faulty cowl vent drain hose, etc. It runs right down the back of the engine, down the bellhousing, into the clutch area. I observed it with my own eyes. It's a good hole to keep open.
#37143 08/12/2003 2:49 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by 4ontheFloor: The water gets in there from water that runs down the cowl due to faulty cowl vent drain hose, etc. It runs right down the back of the engine, down the bellhousing, into the clutch area. Faulty? I thought they were designed that way, so it can't be faulty! Poorly designed better describes it.
Fred 52 3600 69 C-10
#37144 08/12/2003 3:35 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | No argument that the use and location of the cowl-vent drain-hose is a poor design. However, if it is "correctly" routed, it does not seem that a lot of water would find easy entry into the clutch (bell) housing. However, isn't there an opening on the front lower face of that side of the clutch housing that might allow "correctly" drained water to enter?" If there is a hole on that side of the clutch housing, what is it for (seems like a bad design)?
Perhaps 4OTF is referring to the faulty situations wherein the hose is broken or missing (or, maybe the hose is pointed to the center rear of the engine and water drains over the rear top of the clutch housing).
I always thought the hole "6 inches south . . " was designed to direct into a single pan (placed by the owner on her/his garage floor) the mixture of engine and transmission (and differential) lubricants that seemed to leak into the clutch housing from old, or poorly installed, or poorly designed rear seals, oil pan gaskets, valve and side cover gaskets, transmission seals and gaskets, and torque tube seal. Also, any water that "correctly" drains (during a heavy rain) on that side of the engine but finds its way into the clutch housing. Isn't that what you all thought?
The caking of grease and dirt than accumulates on the bottom and side covers of the cluch housing appears to be a common, if not a normal characteristic of these wonderful engines.
This drain hole lets the engine (clutch housing) gently weep (it would be nice to say "weep in one place", but we know better).
Tim | | |
#37145 08/14/2003 10:50 PM | Joined: Jul 2000 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 30 | Mech...crawled under last night, yup it has the screws you mentioned. I took out the cork I nervously jammed in the hole and took the truck down the road. Clutch worked a lot better. Don't know if was my adjustment or just letting the water out!
#37146 08/14/2003 11:30 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Awesome on the clutch working better Most likely it was the truck being happy that you put your hands on it
