1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37126 05/29/2002 12:24 PM | Joined: May 2002 Posts: 23 'Bolter | | 'Bolter Joined: May 2002 Posts: 23 | Need some info please.. My 51 p/u has a 235, 3-speed and open driveshaft. I had the engine rebuilt and have driven it from Florida to Virginia where I now live and I drive it to work in Arkansas. This I have done 3 times, 1500 miles round trip with no problems. Question is the gas mileage? I only get about 11 mpg at around 62 mph. What can I do to improve the gas mileage? Thanks in advance. Pilot | | |
#37127 05/29/2002 1:20 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | To increase your gas milage get a new truck!  Other options include regearing the differential and putting on larger tires.
Fred 52 3600 69 C-10
#37128 05/29/2002 4:33 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | You can change to an over-drive transmission.Or get an overdrive unit to install.You will have to do or have some driveline workdone.
#37129 05/29/2002 6:25 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | What you need is a Borg Warner T-85N Three speed Overdrive transmission. You won't need to do any work to the driveline. Here is a site that will show you exactly what you are going to be looking for at your next swap meet. (I found one at a garage sale for $20 and am putting it in my wifes 55 1st. Borg Warner Overdrive
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#37130 05/30/2002 10:34 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I believe the T -85 transmission is a heavy duty unit normally used by FoMoCo and Stude and don't think it was ever offered with a GM bolt pattern.The base transmission for the Chevy 3 spd OD is the 4 bolt side cover Muncie and the later Saginaw all syncro.The photo in the link is an old Muncie. | | |
