9 members (dt235sd, Gdads51, Gib70, 3B, Phak1, 32Fordpuchoptop, 68ironhead, Jon G, 2-Ton), 79 guests, and 0 robots.
Topics128,049
Posts1,055,693
#37126 05/29/2002 12:24 PM
Need some info please..
My 51 p/u has a 235, 3-speed and open driveshaft.
I had the engine rebuilt and have driven it from Florida to Virginia where I now live and I drive it to work in Arkansas. This I have done 3 times,
1500 miles round trip with no problems. Question is the gas mileage? I only get about 11 mpg at around 62 mph. What can I do to improve the gas mileage? Thanks in advance. Pilot
#37127 05/29/2002 1:20 PM
To increase your gas milage get a new truck! grin Other options include regearing the differential and putting on larger tires.
Fred
52 3600
69 C-10
#37128 05/29/2002 4:33 PM
You can change to an over-drive transmission.Or get an overdrive unit to install.You will have to do or have some driveline workdone.
#37129 05/29/2002 6:25 PM
Oly Offline
What you need is a Borg Warner T-85N Three speed Overdrive transmission. You won't need to do any work to the driveline. Here is a site that will show you exactly what you are going to be looking for at your next swap meet. (I found one at a garage sale for $20 and am putting it in my wifes 55 1st. Borg Warner Overdrive
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#37130 05/30/2002 10:34 AM
I believe the T -85 transmission is a heavy duty unit normally used by FoMoCo and Stude and don't think it was ever offered with a GM bolt pattern.The base transmission for the Chevy 3 spd OD is the 4 bolt side cover Muncie and the later Saginaw all syncro.The photo in the link is an old Muncie.
