4 members (Robert Crandall, farmallb, Steelonsteel, Rick Brown), 149 guests, and 5 robots.
Topics128,108
Posts1,056,239
Members48,437
#370608 02/05/2008 3:18 AM
I am installing a 261 in my 39 pick up that i have already installed a ifs in the front end. i had to cut away part of the original motor mount in front. I am now going to fabricate a new front mount. My question is this: is there an angle at which the engine should tilt towards the back?
any help would be great
thanks
matt
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod
1937 1 1/2 ton Is in the driveway
fatboy0169 #370613 02/05/2008 3:32 AM
3B Offline
Hy fatboy0169, with the truck at ride height the carb mounting flange should be level, hope that helps.
3B #370619 02/05/2008 3:47 AM
Dave Giorgi
Unregistered
Dave Giorgi
Unregistered
Hi Fatboy0169,
Ditto "3b", the carb must be level for the float to work properly.
Dave
#370653 02/05/2008 5:24 AM
see: inland empire driveline service
http://www.iedls.com/ptsetup.html
Jim & Caroline
Set the engine in to where it looks right and DON'T worry about the bubble in the level being exactly between the marks. If the carb had to be perfectly level then vehicles couldn't run uphill, downhill, or on a side slant. No one in San Francisco could have a car. One should have the centerline of the crankshaft close to the centerline of the pinion to prevent driveshaft vibration and wear. There is a lot of posts on this subject but basically you can get a $15 angle finder from Home Depot and set the pinion yoke so it's a degree or two down from the reading you get from the transmission output shaft. This allows the needle bearing in the U-joint cups to roll and prevent flat spots. Take your time, measure carefully (twice), and your project will turn out fine. Good luck
Evan
coilover #371205 02/06/2008 2:10 PM
Dave Giorgi
Unregistered
Dave Giorgi
Unregistered
Mounting the carb flange "level" will give you a 3 degree angle needed at the tailshaft of the transmission which is correct. Check your factory engine and you will see that the carb flange is level from front ot back and side to side. Even though driving up and down for a few hundred yards will not make a noticeable difference it will on a normal long straight a way. Do it the correct way and mount that carb flange level, front to back and side to side.
Dave
