5 members (HandyAndy, 2-Ton, 78buckshot, TUTS 59, Wally / Montana), 91 guests, and 2 robots.
Topics128,060
Posts1,055,835
#37058 07/06/2004 9:27 PM
Junior Member
Junior Member
I am trying to figure out why my newly rebuilt single barrel carb on my 215 pontiac is running rich. The timing is dead on, the idle is pretty steady,but it keeps loading up with fuel when idling, causing a bog when accelerating from a stop. I thought about changing the jet to something smaller but someone told me that won't fix anything because the venturi is matched to that specific jet size. He said I need a new carb. What have you guys done?
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!)
1950 Ford 2 door sedan-project
#37059 07/06/2004 11:49 PM
Have you checked to make sure the power valve is working correctly? Have you checked your float level?
Paint & Body Shop moderator
#37060 07/07/2004 3:11 AM
Junior Member
Junior Member
See above about power valve and then lower float, little at a time, until plugs turn white, then bump it up just a tad. Those carbs are sensitive to float adjustment and the gauge in most kits is only a starting point, but of course they don't tell you that. You will be amazed at the power when the plugs just start turning white.
