| | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | The emergency brake isn't holding at all in my 53 6400. This is a 4 speed trans that I took out of a 55 model 6400 if that makes a difference. The adjustment nuts are all the way up as far as they will go and it still is not holding at all. The old linkage is loose also. Is there a source for a new brake pad and other parts for this? How do I fix it and where do I find the parts? My 65 C60 may be needing this also soon I will have to look at it. Thanks for any info!!!! | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Case_man,
Is this E-brake a band type attached to the rear of the transmission...I think it should be.
You can buy new friction material by the foot and re-line the band yourself. Making sure the assembly isn't saturated with grease would be part of the rebuild.
Stuart | | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | Yes Stuart its on the rear of the trans Its not a band style though the piece with the pad on it covers 7 or 8 inches on the bottom of the brak drum and also has a curved piece that also puts pressure on it from the inside of the drum. Or is this considered a band brake? I can get pics of it soon if need be. Thanks for the help I really do appriciate it!!!!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You have a drum type transmission/driveshaft brake. It works as you describe, by pinching the flange of the drum between an inside and outside shoe.
You can have them relined, or buy the material and do it yourself. As for the rest of the parts, if they are worn look for some different less used ones, doubt you find new stuff, unless NOS.
Grigg | | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | Ok Thanks for the info guess I better get to Napa soon.  | | |
