| | | Forums66 Topics128,128 Posts1,056,666 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | I have a 1970 C50 with a 292, some where there is a exhaust leak at the manifold, thought it was the doughnut so I replaced it ( was leaking there) but it is still loud. I know that they were prone to cracking, but I can only find 1 hair line crack Definitely not big enough to make this noise. gasket at the head, and where the two manifolds go together look ok. It is hard to see the backside are they prone to cracking there? also will a manifold off a pickup fit?
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 292,s are very troublesome with exhaust manifold leaks when used on heavier then 1/2-3/4 ton trucks. It is probably leaking between the manifolds where the intake & exhaust bolt together. It probably has the 2 1/2 in outlet manifold that the outlet points straight down. The light duty manifolds won,t fit. You might check with a GM truck parts dealer & see if a new one is available, although I dought it. If you take them apart it,s very likely you will havev to replace it. They run extremly hot. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 202 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 202 | I have seen new old stock for sale on Ebay. Sometimes good used ones. They do pop up from time to time. I would use cast iron headers from Stovebolt, or Fentons. That will stop the leak and help out with the mpgs and a bit more power. I would have it y'd into a 3" exhaust pipe. It will be quiet yet breathe very well. Just an idea. You can go to Kansas Kustoms and they take your old manifold am=md make a split header out of them with dual outlets. Its not real expensive but a neat way to go. Otherwise it will get worse. I hope this helps. Henry | | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | i've gone thru 3 exhaust manifolds on my '65 sub.w/292 in the almost 40 years i've owned it. I found the problem to be they warp in the back, of course where its hard to see. my truck usually runs cool and i was surprised to find the manifolds had warped. the first two just warped over a period of 10-12 years, the third happened quicker but i was using the original radiator which had a few pinhole leaks, in the arizona desert in summer. if you pull the manifolds you probably will find some evidence of exhasut, like soot or discoloring. torquing the manifolds in the proper sequence to proper torque as listed by chevrolet helps if the manifold is not too warped, double gasketing helped for awhile but bolts seem to work loose fairly quick ,requiring constant retorqueing . i got repalcements at the junkyard from pickups.
i love my dog's 1965 suburban.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | '''''''''You can go to Kansas Kustoms and they take your old manifold am=md make a split header out of them with dual outlets. Its not real expensive but a neat way to go.'''''''''
I have heard recently that KK does NOT do this any more
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
