2 members (Phak1, Pre '68 Dave),
215
Mod | | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 21 Apprentice | | Apprentice Joined: Feb 2008 Posts: 21 | Can anyone give me some advice on what I believe to be a 235 cubic inch engine in my 39 Chevy 1/2 ton truck. There are 5 holes in the drivers side of the block, 2 are taken with a tube connected between them. The other 3 are as follows: 1 near the top back a few inches from the bell housing 1 on the block directly behind the exhaust pipe, low on block 1 about 2/3 the way back from front of block) just right above the top hole taken by one of the tubes. I am trying to put the Fram remote oil filter system in but do not know which holes to use. I also need to know which one is for the oil pressure gauge. Does anyone have a schematic or an idea to use or try. Thanks "1fine39" David | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If it's a '39 engine it's a 216 which should be identical to my 38. Check your email.
| | | | | Joined: Feb 2008 Posts: 21 Apprentice | | Apprentice Joined: Feb 2008 Posts: 21 | I believe its a 235. The upper right could be a petcock for coolant, thats easy to check. How about what remote oil filter line to what plug? The Fram filter has a side port and a bottom port. If I put it in, do I have to put in a "tee" for the oil pressure line? | | |
