0 members (), 139 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
I aquired an Ellis Dualpower Aluminum Intake manifold that I was hoping to use on my 248 GMC engine, but it is quite a bit larger than my current stock manifold. My current 248 intake manifold measures ~18" from center to center of the end intake ports and the Ellis manifold measures 21". It actually has GMC cast into the bottom of one of the Intake ports. Does anyone have any idea what Inline GMC engine this manifold fits? My intake does have 4 numbers cast into the bottom, The first intake port from the front has two numbers 361 & 477, the middle Port has 426, and the back port has 451 GMC. On the side under the DUALPOWER it says "L.A. 23 CAL." Is the manufacturer of Ellis intake manifolds still in buisness?
Jim
The manifold sounds like it fits the large GMC engine like the 308, up to the 503 grin
