| | | Forums66 Topics128,156 Posts1,057,020 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | I have a 49 5 window I am ready to paint the doors and inside the cab. What is the correct color for the door frames on the door and the cab? Is it the same as the door itself? Is the door frame same as the inside color? Thanks | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Outside color goes to the point where the outside skin ends in the door frame, then all the interior is the same color, except for the radio/glove box grille. The original color is commonly called "champagne" by most, hard to describe, get it from a vendor, I like the stuff from chevy duty (their name has changed, and I cannot remember the new name) | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | The steering column and heater are different colors... and by the time this thread is done there will be another couple hundred more suggestions, rumors and facts thrown in with lots of chit-chat.
| | | | | Joined: Dec 2007 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 91 | Thanks I have the interior color "Champagne" If I understane you correctly the interior color will include the inside door frame just below the bottom of the floor and before the running board. The interior color would be around the doors up to the outside color of the truck.
Thanks | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Hi 49chevyman I also have a 49 chevy pickup and asked the same questions back in December 07.. Thought you might be interested in what we had to say on this subject. The forum was started by fellow bolter, czechman 12-18-07,followed by informative discussions by 65 panelmike,adpickup,and info from tcledderman. Mostly about interior vintage paint codes. This informative forum resulted in a Dupont paint code called "GRAPHIC BROWN METALLIC" Dupont jobber code 27467. The back of my radio delete plate still had good paint so I cleaned it up and once the Dupont color was mixed up it was a dead ringer. It has a grayish champagne with hints of brown. I was very pleased with this color hope this will help. | | |
